| Product(s): | SACS |
| Version(s): | ALL |
| Area: | Dynamic Response |
Community Question:
Hello Bentley I'm working in an earthquake dynamic response and when I check the spectrum in graph in chatvue file the values in the graph doesn't match with the values tabulated in the left part, someone could clarify this behavior?
Answer:
First at all I would like to mention that this is not a bug or error in the software. As can you see on the grid distribution of this graph, this is not a common graph; this one is built considering a logarithmic distribution, in this case the base 10 logarithm is used
the coordinates are calculated by this way
X=10^0.77815130 = 6.00
Y=10^-2.116338 = 0.00765
