List of Accepted File Formats in AssetWise Inspections
Product(s): 
Version(s): 
  26.0.5.x
Product Area(s):
 File Upload
Environment(s): 
  n/a
Original Author: 
Purpose
This is a list of the file formats which can be uploaded into AssetWise Inspections.
Audience
End users of AssetWise Inspections
Key Information
Diagramming / Visualization Files
Extension
Full Name
Description
.vsd Visio Diagram (Legacy) Microsoft Visio binary diagram format
.vsdx, .vsdm Visio Diagram / Macro-Enabled (Modern) Office Open XML Visio diagram
Database / Email Files
Extension
Full Name
Description
.mdb
Microsoft Access Database (Legacy)
OLE-based relational database
.msg
Outlook Email Message
Microsoft Outlook email saved as OLE binary
PDF / Fixed-Layout Documents
Extension
Full Name
Description
.pdf
Portable Document Format
Adobe PDF — device-independent fixed layout
.xps, .oxps
XPS / Open XPS Document
Microsoft/ECMA XML Paper Specification — fixed layout
CAD / Drawing Files
Extension
Full Name
Description
.dwg
AutoCAD Drawing
Native AutoCAD binary drawing format
.dxf
Drawing Exchange Format
ASCII/binary CAD interchange format (AutoCAD)
.dgn, .dgnlib
MicroStation Design File / Library
Bentley MicroStation native drawing format
.std
STAAD.Pro Input File
Structural analysis model input (Bentley STAAD.Pro)
.r2d
RAM 2D Model File
RAM Structural System 2D analysis model
.r3d
RAM 3D Model File
RAM Structural System 3D analysis model
.sht
Sheet Drawing File
Engineering drawing sheet file
.ill
LUSAS / Illumination File
Structural analysis or illustration data file
BIM / Architecture Files
Extension
Full Name
Description
.ifc
Industry Foundation Classes
Open BIM standard for building/infrastructure data
.ifcxml
IFC XML
XML serialization of the IFC BIM standard
Geospatial / Survey Files
Extension
Full Name
Description
.dtm
Digital Terrain Model
3D ground surface elevation data
.las
LiDAR Point Cloud
ASPRS LAS format for aerial LiDAR survey data
Mathematical / Scientific Files
Extension
Full Name
Description
.mcdx
PTC Mathcad Prime Worksheet
Engineering calculation sheet (Mathcad Prime)
.xmcd
PTC Mathcad Worksheet (Legacy)
XML-based Mathcad 14/15 worksheet
.alg
Algorithm / Algebra File
Symbolic algebra or algorithm definition file
.mcb
Mathcad Backup File
Backup of a Mathcad worksheet
Video Files
Extension
Full Name
Description
.mp4, .m4v, .mov
MPEG-4 Video
ISO Base Media File Format video
.avi
Audio Video Interleave
Microsoft AVI video container
.mpg
MPEG Video
MPEG-1/2 compressed video
.wmv
Windows Media Video
Microsoft proprietary video format
Audio Files
Extension
Full Name
Description
.mp3
MP3 Audio
MPEG-1 Audio Layer III compressed audio
.wav
WAV Audio
Uncompressed PCM audio (Microsoft/IBM)
.wma
Windows Media Audio
Microsoft proprietary compressed audio
.m4a
MPEG-4 Audio
AAC audio in MPEG-4 container (iTunes/Apple)
Structural / Bridge Engineering — Analysis Files
Extension
Full Name
Description
.anl
Analysis File
Generic structural analysis input/results file
.res
Results File
Structural analysis results output
.out
Output File
General analysis output text/binary file
.mout
Model Output File
Extended model output from analysis software
.stiffness
Stiffness Matrix File
Structural stiffness matrix data
.rwk
Work Session File
Analysis software work/session file
.grh
Graph File
Analysis results graph/chart data
.rgp
Report/Graph Project
Report or graphed project results file
.dc
Design Criteria File
Structural design criteria or DC analysis file
.csp
Construction Specification Project
Engineering project specification file
.cus
Custom Definition File
User-defined custom settings/data
.mdx
Model Data Export
Structural model data export file
.eri
Engineering Results/Information
Engineering output data file
.xfr
Transfer File
Data transfer/export file between applications
.pdi
Profile Data/Index File
Profile or project data index
.thm
Theme/Template File
Application theme or template
.bmd
Bridge Model Data
Bridge structural model data file
Bridge Rating / Inspection — Proprietary Files
Extension
Full Name
Description
.brg
Bridge Rating File
Bridge rating analysis file (e.g., AASHTOWare BrR)
.brsx
Bridge Rating XML
XML-based bridge rating file
.lbcx
Load-Based Capacity XML
Load-based bridge capacity rating file
.lpsx
Load Path XML
Load path analysis file
.ca1
California Bridge Inspection Report
Caltrans CA1 bridge inspection document
.ca3
California Bridge Rating File
Caltrans CA3 bridge load rating form
.ca3b1
California Bridge Rating Variant
Extended CA3 bridge rating sub-form
.etcx
Engineering Tool Configuration XML
Engineering tool configuration/project file
Hydraulics / Civil Engineering Files
Extension
Full Name
Description
.culvert
Culvert Analysis File
Hydraulic culvert analysis (e.g., FHWA HY-8)
.vap
Visual Analysis Project
Visual Analysis structural software project file
.rou
Route / Road File
Highway route definition or road geometry file
Miscellaneous Engineering Files
Extension
Full Name
Description
.xml
XML Data
Generic XML-structured data file
.mdx
MDX / Model Data
Multidimensional expressions or model data
.csp
Civil/engineering specification project
.lis
List / Log File
Plain text listing/output from analysis tools
AssetWise Inspections Help
