Q, Does TTA module calculate the heat transfer film coef. using only the Dittus-Boelter method?
Questions:
Does AutoPIPE's TTA module calculate the heat transfer film coefficient for water using only the Dittus-Boelter method?
Answer:
Yes.
Refer to AutoPIPE's TTA - Theory help for details of the heat transfer film coefficient calculation for water (D1) and heavy water (D2)
"Thermal Transient Analysis" (TTA) - AutoPIPE Load Case
