iTwin IoT and IMSurge have a partnership that enables IMSurge to receive data from different sensor manufacturers (Source) and IMSurge functions as a middle layer that takes that data and pushes it to iTwin IoT (Target).
This will enable you to have a quick integration into iTwin IoT if it is not already existing within iTwin IoT.
For further documentation for this please review these articles from IMSurge.
