Question:
Explain Fatigue Analysis performed in AutoPIPE as per ASME Section III, Subsection NB
Answer:
This article explains the fatigue analysis procedure in AutoPIPE in accordance with ASME Section III, Subsection NB. It describes load set generation, fatigue pairing logic, and cumulative usage factor calculation as performed by AutoPIPE.
This table represents the final fatigue damage calculation.
What is the exact stopping criterion for the ASME NB fatigue iteration process?
The fatigue iteration process in AutoPIPE terminates when the calculated stress or cycle values exceed the valid range of the selected fatigue curve.
For Example, in AutoPIPE model the fatigue curve used is “ASME III – ADLPIPE (Default)”. Since this internally generated curve is limited to 1E6 cycles for carbon steel, the corresponding alternating stress limit is 12,250 psi.
Accordingly, the fatigue iteration stops once the calculated alternating stress falls below 12,250 psi, which indicates that the allowable number of cycles exceeds 1,000,000, thereby going beyond the scope of the curve. In this case, only the first few load set pairs are included in the fatigue usage calculation, while the remaining load set pairs are ignored because their alternating stress values are below the curve limit.
Similarly, for ASME III I‑9.1 and ASME III I‑9.2, the fatigue curves are valid only within the cycle range of 10 to 10¹¹. If the calculated values fall outside this range, AutoPIPE will automatically terminate the fatigue iterations.
What is the workaround to avoid automatic termination of fatigue iterations?
Workaround 1: Since the “ASME III – ADLPIPE (Default)” fatigue curve is limited to 10⁶ cycles, user may consider using alternative ASME III fatigue curves that support a wider cycle range.
Workaround 2: User may create user‑defined fatigue curves (*.FAT) using a text editor with an extended cycle range, provided they follow the required fatigue curve format. These files can be saved either in the model directory or in the AutoPIPE program directory. AutoPIPE assumes log‑log interpolation between the defined data points.
