AutoPIPE Vessel 2026 (47.00.01.027:2026-03) Readme File
Notes: Read the News Release Announcement here.
Product
Bentley AutoPIPE Vessel
Version
47.00.01.027
Language
English
Date Posted
English - March 2026
Platforms
Microsoft Windows 11 Professional or higher
64 bit OS
.NET Framework
4.8 (4.8.4115.0)
What is New & Changed in AutoPIPE® Vessel
The following outline identifies new features and enhancements in the AutoPIPE Vessel 2026 (47.00.01.027).
The following outline identifies new features and enhancements in the AutoPIPE Vessel 2026.
  • Enhancements
    • User Interface
      • Added a delete function (with multiple selection) to the "Change Nozzle" dialog box.
  • Defects
    NOTE: Problems described below represent specific issues with specific test cases. It is difficult to succinctly describe a problem and how it impacted the specific test case. If you have any questions about the issues discussed in this report, please contact technical support.
    • Calculation / Report
      • #2007548: ASME VIII-1 (2025) - External forces and moments are considered twice.
      • #2012687: ASME Materials N06625 - Thermal expansion coefficient group is N07750 and should be N06625.
      • #2001611: ASME Material - For material where Note G5 is selected but not applicable, the program determines an allowable stress based on Yield stress and Tensile Strength.
      • #1997864: CODAP 2025 Report labels Division 1 for Tubesheets despite Division 1 not being available.
      • #2004461: Local Load PD5500 G.2 - Runtime Error when checking the circumferential moment on cylindrical shell as per G.2.3.6 only when K1 (Table G.2.2-1) is greater than 5.
      • #2010105: External pressure: Internal stiffener at conical junction is modified as external stiffener when dimensions must be increased.
    • User Interface / Others
      • #1997709: GUI - The dimensions of the selected profile/shape are no longer displayed in the dialog boxes (Stiffeners, Legs ...).
      • #1998109: 2D Drawing - The drawing interface crashes when a Demister Pad is not properly defined.
      • #2020492: GUI - User Case - The allowable stress case modification must be validated twice to be taken into account.
  • Customizable Files
    NOTE: Version 3.9
    • Config\Material.emdm (Material Database) (Updated)
  • EMVD schema version: 8.0
  • Security Release Notes
    • None
AutoPIPE®  Vessel Requirements
This document contains information regarding:
  • Product Version
  • Installation Requirements
  • Minimum Profile
More detailed installation information can be found in the AutoPIPE Vessel Quick Start Guide.
Product Version
Product
AutoPIPE Vessel
Version
47.00.01.027
Language
English
Access to the Internet required for product installation. The minimum system configuration for installation:
Operating System
Microsoft Windows 11 Professional or higher 64-bit OS
When installing the product through the installer program, the required components will be installed automatically.
  • Microsoft Visual C++ 2022 Redistribuable (14.42.34433.0)
  • Microsoft .NET Framework 4.8 (4.8.4115.0)
  • Bentley CONNECTION Client (25.0.2.19)
Minimum Profile
The minimum recommended workstation profile for running AutoPIPE Vessel is:
Processor
Intel® or AMD® processor 3.0 GHz or greater.
Memory
4 GB of free (1) RAM minimum, 8 GB or more is preferred. AutoPIPE Vessel will utilize all available RAM. AutoPIPE Vessel performance is dependent on the size of the AutoPIPE Vessel model and the amount of available system resources.
(1) Free RAM refers to available RAM after all operating system processes have been loaded.
Hard Disk
4 GB free disk space.
Video Graphics Card
Any industry-standard video card which supports OpenGL 3D graphics.
Screen resolution of 1280x1024 or greater.
CAD
AutoCAD x64 versions: 2019, 2020, 2021, 2022, 2023, 2024, 2025, 2026
BricsCAD x64 versions: 2022, 2023, 2024, 2025, 2026
SolidWorks x64 versions: 2018, 2019, 2020, 2021, 2022, 2023, 2024, 2025, 2026
CAD viewing
Bentley View (Free viewing software for DWG, IFC, DGN)
Adobe PDF Reader
To view, print, and save PDF files, Bentley recommends Adobe Reader 10 or higher.
Word / Excel
To view, print, and save Report files and edit customizable files, Bentley recommends Microsoft Office 2013 or higher.
Download and Installation
See this link to a wiki page for more information on downloading and installing AutoPIPE Vessel.
To complete the licensing process, you must have the appropriate roles assigned by your Site Administrator by submitting a Service Request at https://aka.bentley.com/AutoPIPEVessel.Bentley.TechnicalSupport.
If you are experiencing problems logging into your Bentley account, please contact Bentley at 1-800-BENTLEY (1-800-236-8539). Outside the United States +1 610-458-5000.
Included Applications in the Installation Package
AutoPIPE Vessel is installed from one executable. The configuration of AutoPIPE Vessel includes these features:
  • ASME VIII Div.1 & Div. 2 Code
  • BS PD 5500 Code
  • CODAP Div.1 & Div. 2 Code
  • AD MERKBLATTER Code
  • European Standard EN 13445 Code
  • Russian GOST R 52857 Code
  • Chinese GB 150 Code
  • Considering pressure, temperature, external loads, wind, earthquake and local loads
  • Creating calculation report using English, French, German, Russian, Chinese language
Design Codes
This sections contains the list of design codes and code editions supported by AutoPIPE Vessel.
  • Pressure Vessel/Heat Exchanger Code
  • Manufacturing Standard
  • Wind Code
  • Seismic Code
  • Nozzle Local Load Method
Design Code
Description
Editions
AD/AD 2000-Merkblatt
Code for Pressure Vessels (German Code)
2022-03, 2016-09, 2014-11, 2012-07, 2011-05, 2007-11, 2007-05, 2004-10, 2003-01, 2000-00, 1996-08, 1995-07, 1995-05, 1993-04, 1991-10, 1990-10
API 650
Welded Tanks for Oil Storage
2016-01, 2014-09, 2013-03, 2011-09
ASME VIII Division 1
Rules for Construction of Pressure Vessels
2025-07, 2023-07, 2021-07, 2019-07, 2017-07, 2015-07, 2013-07, 2011-07, 2010-07, 2009-07, 2008-07, 2006-07, 2005-07, 2004-07, 2003-09, 2002-07, 2001-07, 2000-07, 1999-07, 1998-07
ASME VIII Division 2
Rules for Construction of Pressure Vessels (Alternatives Rules)
BS/PD 5500
Specification for Unfired Fusion Welded Vessels (British Standard Institute)
2024-01, 2015-04, 2014-09, 2013-09, 2012-09, 2012-06, 2011-09, 2011-01, 2008-01, 2006-09, 2005-11, 2004-09, 2004-03, 2002-08, 2002-04, 2001-01, 1999-11
CODAP
Code for Construction of Unfired Pressure Vessels (French Code)
2025, 2022, 2018-07, 2016-10, 2015-10, 2014-06, 2012-10, 2011-03, 2010-11, 2009-03, 2007-09, 2006-06, 2004-12, 2004-04, 2002-12, 2000-12
EN 13445
Unfired Pressure Vessels (European Standard)
2021-05, 2020-07, 2017-12, 2016-09, 2015-07, 2014-09, 2013-07, 2011-07, 2009-07, 2007-04, 2004-11, 2004-02, 2002-05
GOST 34233
GOST R 52857
Vessels And Apparatus (Russian Code)
2018-08, 2012-01, 2008-01
NFE 32 100-108
French Code For Construction Of Steam Generators
1988-12
GB 150
Pressure Vessels (Chinese Code)
2011
Design Code
Description
Editions
EJMA
Standards of the Expansion Joint Manufacturers Association
2016 (10th Edition), 2008 (9th Edition)
TEMA
Standards of the Tubular Exchanger Manufacturers Association
2024-07 (11th Edition), 2019-04 (10th Edition), 2007-11 (9th Edition), 1999-06 (8th Edition), 1997-12 (7th Edition), 1991-08 (7th Edition)
Wind Code
Design Code
Description
Editions
AD-Merkblatter S3/0
General Verification Of Stability For Pressure Vessels
1991
ASCE 7
Minimum Design Loads for Buildings and Other Structures
2022, 2016, 2010, 2005, 2002
British Standard BS 6399 Part 2
British Standard for Loading for Buildings - Code of Practice for Wind Loads
1997
EN 1991-1-4
Eurocode 1: Actions on Structures - Wind Actions
2010, 2005
GOST 34283
GOST R 51273-99
Vessels and Apparatus NORMS AND METHODS OF STRENGTH CALCULATIONS Rated Strength
2018, 2000
IBC (ASCE)
International Building Code
2024, 2018, 2015, 2012, 2006
Indian Standard IS:875 Part 3
Indian Standard - Wind Loads on Buildings and Structures
1987
NBC Canada
National Building Code of Canada
2005
NBR 6123
Brazilian Code - Wind Load
1998
Neige et Vent 65
French Wind Code
1999, 1995, 1990
Portuguese DL 235/83
Portuguese Wind Code
1983
Spanish Code NBE AE 88
Spanish Wind Code
1988
Uniform Building Code
US Code Until 1997
1997
GB 50009
Chinese Wind Code
2012
Seismic Code
Design Code
Description
Editions
ANSI A58.1
1982
ASCE 7
DIN 4149
German Earthquake Standard
2005-04
EN 1998-1
Eurocode 8: Design of Structures for Earthquake Resistance
2013, 2004
GOST 34283
GOST R 51273-99
Vessels and Apparatus NORMS AND METHODS OF STRENGTH CALCULATIONS Rated Strength Calculation of Column Type Apparatus from Wind Loads and Seismic Influence
2018, 2002
IBC (ASCE)
Indian Standard IS:1893
Indian Standard
2015, 2005, 2002
NBC Canada
2005
Parasismique PS 92
French Standard
1995
Portuguese Earthquake LNEC
Hazard Analysis and Seismic Risk Assessment in Portugal
1987
Spanish Code NCSE-02
Spanish Seismic Code
2002
US Code Until 1997
1997
GB 50011
Chinese Seismic Code
2010
Design Code
Description
Editions
EN 13445
Par. 16.4 and 16.5 Local Loads on Nozzles in Spherical Shells / in Cylindrical Shells
GOST 34233
GOST R 52857
Par. 6 Strength Calculation of Cylindrical Shells and Spherical Bottoms Under External Static Loads on the Nozzle
2018-08, 2008-01
PD 5500 G2
Par. G.2 Local Loads on Pressure Vessel Shells
2024-01, 2021-01, 2015-04, 2014-09, 2013-09, 2012-09, 2012-06, 2011-09, 2011-01, 2008-01, 2006-09, 2005-11, 2004-09, 2004-03, 2002-08, 2002-04, 2001-01
PD 5500 G.2.8
Par. G.2.8 Alternative Rules for Local Loads on Circular Nozzles in Spherical and Cylindrical Shells
WRC B 107 + 297
Local Stresses In Spherical And Cylindrical Shells Due To External Loadings
2002-10
WRC 537
Precision Equations and Enhanced Diagrams for Local Stresses in Spherical and Cylindrical Shells Due to External Loadings for Implementation of WRC Bulletin 107
2010
How to Activate AutoPIPE Vessel ®
Subscription Entitlement Service is Bentley's new licensing model, providing enhanced security and optimized value for your Bentley Subscriptions. It is integrated with Bentley's Identity Management System (IMS) and the Bentley CONNECT technology platform to allow near real-time reporting of usage, improved alert messaging to users and increased administrative capabilities to license administrators in your organization. It will not only give you more options to monitor and manage usage but also provide new, advanced licensing features that will enhance digital workflows.
Activation
With Subscription Entitlement Service, all users must be registered with Bentley's Identity Management System (IMS) and sign in to the CONNECTION Client to access Bentley applications. Product activation will now occur through user sign-in to the CONNECTION Client with a valid IMS ID associated with their account. User sign-in will replace traditional activation keys, offering enhanced security as administrators will be able to control which users have access to Bentley software. License entitlements are granted and maintained through Subscription Entitlement Service's Entitlement Management Service. By signing into the CONNECTION Client users can also find their organization's projects, download software updates, receive relevant notifications, and track their usage.
Alerts
Subscription Entitlement Service features the new license alerts notifications that can be set by an organization's license administrators to let the users know when they reach a set usage threshold. These notifications will alert the users that if they continue to use the product, a term license may be issued. The user in such a situation has the choice to quit the application before a license is used or acknowledge that a term license may be generated and proceed with starting the application, based on what settings the administrator chooses.
Copyright
TRADEMARK NOTICE
Bentley, the "B" logo, AutoPIPE, MicroStation, ProjectWise, SELECT, and MDL are either registered or unregistered trademarks or service marks of Bentley Systems, Incorporated, or one of its direct or indirect wholly-owned subsidiaries. Other brands and product names are trademarks of their respective owners.
COPYRIGHT NOTICE
© 2026 Bentley Systems, Incorporated. All Rights Reserved.
Including software, file formats, and audiovisual displays; may only be used pursuant to applicable software license agreement; contains confidential and proprietary information of Bentley Systems, Incorporated and/or third parties which is protected by copyright and trade secret law and may not be provided or otherwise made available without proper authorization.
Complete copyright information can be found in the product by choosing Help > About.
For reference, a copy of the End User License Agreement named "Eula.pdf" is included in the "AutoPIPE Vessel" folder of the product installation. By default, this location is "C:\Program Files\Bentley\AutoPIPE Vessel."
Corporate Headquarters
685 Stockton Drive
Exton, PA 19341, United States
1-800-BENTLEY (1 800 236 8539)
+1 610 458 5000
Bentley EMEA
Bentley Systems International Limited
Charlemont Exchange
5th Floor, Charlemont Street
Dublin 2, D02VN88, Ireland
1800 948 368
+353 1 436 4600
Bentley Asia
Bentley Systems (Beijing) Co., Ltd.
Unit 1402-06, Tower 1
China Central Place
Beijing 100025, China
400 842 7516
+86 10 5929 7000
Bentley Support Portal
AutoPIPE Vessel Information
AutoPIPE Vessel Forum
AutoPIPE Vessel Landing page
How do I install and license AutoPIPE Vessel?
Readme Release Notes for AutoPIPE Vessel
