SELECTserver Licensing Landing Page
CONNECT Center Landing Page
Subscription Services Landing Page
User Management Landing Page
Entitlement Management Landing Page
Subscription Analytics Landing Page
SES Licensing Landing Page
CONNECTION Client​ / Bentley License Tool​ Landing Page
ProjectWise / Web Portal Licensing Landing Page
Product Specific Licensing Landing Page
SELECTserver
General
Glossary Of Licensing Terms [FAQ]
Trust Licensing Basics [FAQ]
SELECTserver to SES Migration Guide
Activation of SELECTserver licenses through SES
Where do I find my Activation Key?
Activating Against SELECTserver OnLine (a Bentley hosted server)[TN]
Managing SELECTserver Activation Keys in SES
Activating Applications Using SELECTserver Based Licensing as a non-SELECT User
License Management Tool
Opening License Management Tool
Open License Manager in MicroStation CONNECT Edition (none SES version)
Group Policy Administration (ADM) files
IP Address Hosted Server
Support for V8i applications after December 31st, 2021
DISCONNECTED MODE EXPLAINED [FAQ]
Using Active Directory Group Policy Objects to Configure Licensing for Users Centrally (video).
Data Update Service Warning [TN]
Activating Non-Licensed Trial Mode Software
SELECTservices TechNotes and FAQs
License and SELECTserver Administration [FAQ]
SELECTserver based Activation
Announcement: Deprecation of SELECTserver import of restricted applications and checkout restriction
Prevent unauthorized SELECTserver Activation Key based Usage
SELECTserver Ports and Domains
SELECTserver License Troubleshooting
Generating a License Debug Log
Error 1068: Cannot start the Bentley SELECTserver service
No valid customer
Troubleshooting Product Activation for XM and Higher
Troubleshooting a License As Expired message [TN]
Troubleshooting a License as Expired message [TN] version 2
SELECTServer Checkouts
Client Check In and Out Instructions for XM and Higher
How to Check Out / Check In licenses from Entitlement Management
Importing a Checked Out License (XML file) for XM and Higher [TN]
Client Check In and Out Instructions for XM and Higher [TN]
Client Check In and Out Instructions for Pre-XM [TN]
Can I restrict license usage to checkouts only?
Viewing And Checking In Licenses Using The Site Administration Page [TN]
Deployed SELECTserver
About SELECTserver
Deployed SELECTserver Knowledge Requirements [TN]
Deployed SELECTserver Technical Requirements [TN]
SELECTserver Online Technical Requirements [FAQ]
https://bentleysystems.service-now.com/community?id=kb_article_view&sysparm_article=KB0020166
Opening Administration Site
Import xml File on Deployed Server
Manual Installation of SQL Express (2008 - 2012)
Moving Your SELECTserver Database
How to create a Virtual Directory in IIS7
Understanding the (Legacy) SELECTserver Workflow
Moving (relocating) the SELECTserver application to a new server.
Online License Tool [FAQ]
Server does not support this Activation Key
SELECTserver 9.xx.xx.xx Upgrade Information [FAQ]
SELECTserver 9 Known Issues
What's New in the latest SELECTserver?
Older SELECTserver Versions
The SQL transaction logs are full
Error 417 : in SELECTserver and GateWay logs
Enabling Diagnostic Logging for SELECTserver
SELECTserver Database Backup [TN]
SELECTserver XM Database Backup [TN]
Admin Check In and Out Instructions for XM and Higher [TN]
SelectServer V9 without connectivity and Bentley Passport
Gateway startup failed: Error in XML document
How To Install a Gateways on Vista and Windows 7, Server 2008
Activating Against a Locally Deployed SELECTserver [TN]
Announcement: Posting of usage from the deployed SELECTserver no longer supports TLS 1.0/1.1
Restricting access to a deployed SELECTserver Administration Site. Configuration example (video).
Database Setup Tool Configuration and Explanation [FAQ]
Options available to allow the external (WAN) user to access a Locally Deployed SELECTserver
Deployed SELECTserver License Troubleshooting
Transmit Usage Logs - 0 Logs Found To Process [TN]
The response file corresponding to the following logs is not processed.
Could not load type 'System.ServiceModel.Activation.HttpModule' from assembly 'System.ServiceModel..
"An Error Has Occurred" when manually transmitting usage logs using a preconfigured URL
Response File larger than 7.93 MB - Error 404
SELECTserver Gateway
How to license V8 2004 and earlier products
SELECTserver Gateway Explained
Pointer File Explained for Pre-XM Products [FAQ]
SELECTserver Gateway Troubleshooting
Create advanced Gateway Log file
SELECTserver Gateway Issues
How to check if the installed SELECTserver Gateway is running properly
SELECTserver Gateway will not start
SELECTserver Gateway error 1053
SELECTserver Gateway error 1067
SELECTserver Gateway Service Fails To Connect through Proxy Server [TN]
Deployed SELECTserver issue with new Bentley SSL certificate
HTTP Error 404.13 "The request filtering module is configured to deny a request that exceeds the req
HTTP Error 500.21 - Internal Server Error on SELECTserver Administrative Site
SQL Server 2005 Cachestore Flush Error
SQL Server Compatibility Mode - Internal Query Processor Error
Windows could not start the Bentley SELECTserver Gateway service
SELECTserver 9.xx.xx.xx Gateway Update Process [FAQ]
SELECTserver Gateway License Server Revoked License [TN]
SELECTserver Gateway will verify but not start
SELECTserver Gateway Service will not Start
SELECTserver Gateway Service Will Not Start
How do I configure Client Access Restrictions for products using the Gateway?
SELECTserver Gateway Service Causes 100% CPU Usage
The Gateway Stops Before 30 Days
The Gateway service will not start and the license tool crashes on servers running Intel Pentium III
SELECTserver Gateway Service won't start when using Windows Authentication
SELECTserver Gateway, Windows services Fails to Start
Gateway fails to start because license is not valid
Installation Error "Action only valid..."
Pre-SELECTsrver Based Activation
License File Names 8.0 & Below [TN]
Product License Filenames
Troubleshooting Product Activation for Pre-XM Nodelock [TN]
Troubleshooting Pre-XM Client Error Messages with Server Based Licensing [TN]
Activation of Client Side Products and Registry Basics
