Q. Whay does Wall thickness and Material change when exporting a PCF file from AutoPIPE?
Answer:
Correct. When exporting a model from AutoPIPE, any properties that are not mapped correctly will changed to default settings. To prevent this, update the map file to ensure those properties are mapped correctly.
