Q. How to adjust the orientation of PCF piping by 180 degrees?
Answer:
Importing issue:
Beforepressing the Convert button, select the Coordinates tab, and make adjustments as needed.
The press the convert button again.
Export issue:
Before export to PCF from AutoPIPE, In AutoPIPE  Go to Isogen Settings
Change North arrow as needed, then the coordinates will match exactly
