Registering your organization’s email domain allows Bentley to verify users signing up with a specific domain belong to your organization. Once a domain is verified, administrators can enable automatic user approval, allowing new users with matching email domains to be automatically added to the organization without manual review.
This reduces administrative overhead and ensures users can quickly access Bentley products and services.
Domain registration and auto‑approval are managed in the Admin Portal by Account Admins.
company.com).gmail.com or outlook.com cannot be registered.If you do not have the above access, speak to your company IT admin or provider.
Here you can view all domains associated with your organization, including their ownership and verification status.
Adding a domain initiates the ownership verification process required before the domain can be used for auto‑approval. To confirm that your organization owns the domain, choose one of the following verification methods.
Add a unique text string that we provide to your DNS settings. This proves you have administrative access, which confirms your ownership of the domain.
company.com or subdomain.company.com) see additional instructions for subdomains below.Once the TXT record is detected, the domain status updates to Verified. Please not it can take up to 48 hours for verification to be completed depending on your hosting provider.
Upload a unique HTML file that we provide to the root directory of your website. This proves you have the ability to manage your site's files, which confirms your ownership of the domain.
https://company.com/verification.html).When the file is successfully validated, the domain status updates to Verified.
After a domain is verified:
When auto‑approval is enabled, users who register with an email address matching the verified domain are automatically approved and added to the organization.
When auto-approval is disabled, users will appear in the Access requests tab in the User Directory and require Admin approval before being added to the account.
From the Domains page, administrators can:
Removing a domain stops automatic approval for that domain and may require future users to be manually approved.
When registering a subdomain (for example, dv1.xyz.com), the value you enter in the Name / Host field of your DNS TXT record depends on which DNS zone you are editing with your domain provider.
This distinction is important. Entering the wrong value will cause domain verification to fail.
@ represents the root of the current DNS zone@ or the subdomain name (for example, dv1), not bothIf:
dv1.xyz.comxyz.comThen:
dv1dv1.xyz.comUse this when the subdomain does not have its own DNS zone.
If:
dv1.xyz.comdv1.xyz.comThen:
@ (or leave blank if your provider defaults to @)dv1 in the Name fieldImportant:
If you enter dv1 in this case, domain verification will fail, because the record will be created at dv1.dv1.xyz.com.
| Target Domain | DNS Zone You Are Editing | Name / Host Value |
xyz.com |
xyz.com |
dv1.xyz.com |
xyz.com |
dv1 |
dv1.xyz.com |
dv1.xyz.com |
@ is not combined with subdomain names@ always means “this DNS zone”
