W2261-113:B31 App J: Tee header legs are not collinear... message appears in AutoPIPE, why?
Problem:
The following is displayed when using AutoPIPE
Why and how to avoid it?
Generally, this warning is issued when the tee header outgoing pipe is not completely aligned with the incoming tee header pipe at least at one node before / after a tee node point.
The solution is simple, make sure the tee header incoming and outgoing pipes are completely aligned.
In March 2026, a service case (2019328) regarding this message appears for an aligned tee header. There is no workaround to removing this message. Please know that this is merely a warning and should not impact the analysis or results. This warning message can be disregarded after verifying that the header piping surrounding the tee node point is properly aligned.
