EasyPower FAQs
Product Overview
What is EasyPower and what is it used for?
EasyPower offers software tools that simplify complex electrical power system analysis, making it easier to model, analyze, and deliver solutions across all power system lifecycle phases. You can quickly model electrical power systems, perform advanced simulations, and produce essential project deliverables and safety documentation.
What types of electrical systems can I model in EasyPower?
You can quickly model electrical power systems including three-phase, single-phase, AC, and DC systems with manufacturer-specific components. The software allows you to build integrated one-line diagrams using a large library of equipment created from manufacturer specifications.
What specific power system studies can I run with EasyPower?
Users can perform advanced simulations to address complex power system challenges, including:
  • Short Circuit
  • Protection Coordination
  • Arc Flash
  • Power Flow
  • Harmonics
  • Transient Motor Starting
  • Reliability
  • Dynamic Stability
Does EasyPower offer automated design features?
Yes. The Auto Design module can automatically size the following based on load requirements to support design standards and compliance:
  • Cables
  • Transformers
  • Protective devices
  • Panelboards and switchgear
  • Motor control centers (MCCs)
How does EasyPower help with arc flash compliance and NFPA 70E?
EasyPower performs arc flash and shock hazard assessments to determine PPE requirements, generate compliant arc flash labels, and create work permits for electrical safety. It also provides tools to support alignment with NFPA 70E requirements.
What reports and deliverables can I generate for my project?
EasyPower can create a range of reports and deliverables, including:
  • Single-line diagrams and drawings
  • Technical reports in text and spreadsheet formats
  • Time-current curves (TCCs)
  • Graphical plots and charts
  • Arc flash labels
  • Energized electrical work permits
  • Panel and MCC schedules that can be exported to spreadsheet or CAD (DXF) formats
What training options are available for EasyPower?
EasyPower offers both expert-led training and self-paced learning resources for different skill levels:
  • Self-Paced Online Training: Free on-demand courses on the Bentley Learn platform, including Hands-On Training, Protective Device Coordination, Arc Flash Risk Assessment, and XGSLab and Grounding Analysis.
  • Live 5-day Essentials Training
  • Custom one-on-one web training
  • Client-site team training
  • Help System: Press F1 in any dialog box or click the Help icon. Help is also available online.
  • Tutorials and User Manuals: Tutorials are available online through EasyPower Help, as printable PDFs from the Start Page under Resources & Tutorials, and as in-product step-by-step guides. A full PDF User Guide is also available from the Start Page.
  • Video Library: An extensive video library covers specific EasyPower tasks as well as general industry topics.
For more information, visit the EasyPower Training page.
Installing the Software
I was issued a trial when opening EasyPower. How do I access my license instead?
To access your EasyPower license, use the Feature Level Selector when installing the program. After downloading EasyPower:
  1. Open the Windows Start menu and search for Bentley Licensing Tool.
  2. In the window that appears, choose Tools > Select Feature Level.
  3. This window may take a moment to load. Select the EasyPower feature string available to you.
Note: You should only need to make this selection once, unless you need to change active licenses.
How can I access EasyPower if my company is on E365?
Account administrators need to contact their Enterprise Success Manager or Account Manager to have their EasyPower license or licenses added to the E365 program.
What are the minimum system requirements?
Component Requirement
Operating System 64-bit Windows 10 or 11
CPU Multi-core processor
Memory 8 GB minimum (16+ GB recommended)
Disk Space 2 GB free (10+ GB recommended)
After installing, how do I run the program?
First, sign in to the Bentley Connection Client. Then click the Windows Start button and search for EasyPower or EasyPower Demo if you have the demo version.
Can I install multiple versions of EasyPower on the same machine?
Yes. You can have multiple versions of EasyPower on the same machine. For example, if you already have EasyPower 11.0, you can also install EasyPower 2025 without overwriting version 11.0. The new version will be installed in a separate program folder.
What is the default location for EasyPower program files?
The default folder for EasyPower is C:\ProgramData\EasyPower\EasyPower. You can choose a different folder during installation.
How do I uninstall EasyPower or EasyPower Demo?
Windows 10/11: Uninstall the program from the Windows Control Panel.
Older versions of Windows: Select the Windows Start button, then Settings > Control Panel > Add/Remove Programs. Select EasyPower and choose Remove.
Can I add or modify EasyPower's device library?
Yes, you can customize your device library. We are also happy to add devices that are not currently in EasyPower, or we can show you how to do this yourself.
Using the Software
How do I print the one-line with the arc flash hazard results?
After running the arc flash calculations, click Print and select the printer or plotter you want to use.
How do I create an arc flash hazard report?
  1. From within Short Circuit, select Short Circuit Options > Arc Flash Hazards.
  2. Under Create Report, select the Arc Flash Spreadsheet check box.
  3. After running the arc flash calculations, view the report by choosing Window from the menu.
How do I create arc flash hazard warning labels?
In the Arc Flash Hazard Report window, select File > Print Label > All Devices or Selected Devices. Then select the appropriate label printer in the print dialog box.
Can I save warning labels as a PDF file for printing later?
Yes, if you have a PDF writer installed, such as Adobe Acrobat or Adobe PDF. From the arc flash hazard report:
  1. Select File > Print Label > All Devices or Selected Devices.
  2. In the print dialog, select your PDF writer instead of a label printer.
  3. Provide a file name when prompted.
Can I add comments to warning labels?
Yes. When you print the labels, the print dialog includes a comment field at the bottom. Enter the text you want to add and it will appear on the printed label.
How do I disable arc flash hazard calculations for specific nodes or equipment?
  1. In Database Edit mode, double-click the equipment to view its data. This must be a bus, MCC, panel, or ATS.
  2. Select the Arc Flash Hazard tab.
  3. Select the check box for Exclude this bus from arc flash hazard report.
