Q. Why the support type changed automatically from spring hanger to v-stop support?
Question:
Answer:
The only reason AutoPIPE would automatically modify a support occurs during these two operations:
    1. Analyze all - with hanger selection enabled
    2. Spring Hanger Selection
When conducting a hanger analysis, the program will determine whether to utilize the Variable Spring hanger, change it to a Constant Support, a V-stop support, or remove the support altogether.
