Limited availability of UDSM State Parameters in Output when using multiple UDSM in one phase
Application PLAXIS 2D, PLAXIS 3D
Issue status Solved
First Affected Version PLAXIS 2D 2025.1.0
PLAXIS 3D 2025.1.0
Found in Version PLAXIS 3D 2025.1.0.1991
Fixed and Released in Version PLAXIS 2D 2026.1
PLAXIS 3D 2026.1
Issue # 1985660 / 1987089
Date created 18 February 2025
Date modified 29 October 2026
Keywords PLAXIS, State Parameters, USDM
Symptoms
Users may experience one or more of the following symptoms when reviewing results in Output:
These symptoms can make it challenging to fully interpret results when advanced soil model analyses rely on multiple UDSM.
Problem description
In PLAXIS 2025.1.x, when multiple different User Defined Soil Models (UDSM) are assigned within the same calculation phase, not all state parameter results are available for contour plotting in Output. In such cases, Output only exposes the state parameter results of the first UDSM encountered, while state parameters belonging to other UDSM used in the same phase are not shown.
This limitation affects all User Defined Soil Models (UDSM), including models delivered with PLAXIS (such as NorSand, PM4Sand, PM4Silt, CASM, N2PC) as well as user‑imported UDSM DLLs.
When this issue occurs
This issue occurs when:
When this issue does not occur
This issue does not occur when:
Impact
All State parameter results are available via the table view and selected curve points
Due to the complexity of the behaviour and timing constraints, this issue could not be fully resolved in the current update packs.
Solution / Workaround
This issue is now resolved with the release of  PLAXIS 2D/3D 2026.1.
Two workarounds are currently available.
Option 1 – Continue using PLAXIS 2024.3 (Recommended)
For projects that:
We recommend continuing to use PLAXIS 2024.3, where this limitation is not present.
This provides the most reliable workflow for advanced UDSM‑based modelling.
Option 2 – Use a workaround in PLAXIS 2025.1.x (Limited)
A workaround is available under specific conditions.
How the workaround works
If there is at least one phase in which only one UDSM is active, Output allows you to select state variables for that model. Once selected, the chosen state variable remains available when switching to other phases.
Steps
  1. Open Output for a phase where only one UDSM is active.
  2. Select the desired state variable for contour plotting.
  3. Switch to another phase of interest.
    The selected state variable remains available.
  4. Review the results.
  5. To view a different state parameter, repeat the process starting from a phase where the corresponding UDSM is the only active model.
Important notes
