Error 695 - SUPPORT: the vessel is a 'Vertical on Leg or Bracket' type, incompatible with the presen
Problem:
The following message appears when using AutoPIPE Vessel,
Error 695 SUPPORT: the vessel is a 'Vertical on Leg or Bracket' type, incompatible with the presence of a skirt, revise input data.
why and how to avoid?
This error occurs when:
In AutoPIPE Vessel, the support type is a fundamental property that is fixed at the time of vessel creation.
Attempting to introduce a skirt to a vessel originally defined as leg- or bracket-supported creates an unsupported and inconsistent model configuration, which triggers Error 695.
Technical Explanation
Resolution
Changing a vessel from Legs or Brackets to a Skirt-supported configuration after creation is not recommended and not supported.
Only the following support-type changes are supported in AutoPIPE Vessel:
Any conversion to or from a skirt must be defined during initial vessel creation.
Workaround
To avoid or resolve Error 695, use one of the following workarounds:
        1. Recreate the vessel with the correct support type:
          • Start a new vessel model.
          • Select Vertical Vessel on Skirt with Anchoring during the initial creation process.
          • Re-enter all geometry, material, load, and design data.
        2. not add a skirt to an existing leg- or bracket-supported vessel:
          • Skirts cannot be retrofitted through input data changes.
        3. Use supported support conversions only:
          • Convert between Legs and Brackets, or
          • Convert Saddles ↔ Legs / Brackets, if design intent allows.
Bentley AutoPIPE Vessel
Support Solutions and FAQ's
Error Messages
Warning Messages
Calculations
