| Product(s): | SACS |
| Version(s): | ALL |
| Area: | Collapse |
Community Question:
Hello Bentley, I'm working on an in-place analysis and I have two scenarios:
Plastic ratio is the ratio of number plastic sub-areas (or integration points) to the total number of the subareas (or integration points) within a given cross-section.
For plastic deformation (strain), SACS has options that you can select in the card CLPRP inner of your collapse control file; using column 58-59 you can access the different reports of stresses on elements.
We don't have the graphics sub-areas in Standard Collapse. But for Collapse Advanced please see figure 2 in Collapse Advanced user guide for the location of the integration points.
You can activate the report of stresses on integration areas by activating the field shown below.
The troubleshooting file is active only when you run using collapse advance
NSLV is number of solves of linearized system. In a nonlinear analysis, at each iteration, the stiffness matrix is updated and then the program solves the linear system.
Sometimes it is a tricky task to improve the time of solving analysis, but in theory you can reduce the time depending on your model. A good recommendation is to set two or three segmentations in all tertiary and secondary elements, while for the interested elements, specify a higher number of segmentations. Normally, SACS considers all modeled beams divided into 8 subsegments along the length for analyzing. You can change these criteria using the next commands, MEMSEG and MEMSEG.
When you face this issue,
It's recommended reviewing the E and Fy on the element with this joint, and if this belongs to a reference structure (dummy) or tertiary structure, and if the result of these doesn't influence the structure collapse, so increase the rigidity on them (diameter and thickness). This is going to avoid the joint will displace and will help us to reach the convergency fast. When we have flexible structures, whit nodes who displace much, usually SACS takes time to reach convergency Most of the cases are linked to the difficulty of reaching the convergence of elements during this type of analysis. We recommend checking this wiki for troubleshooting.
If you feel some outcomes from any module of SACS are wrong or could be calculated wrong, please don’t hesitate to send your model for our test and investigation. This way, we can share the files with the developers for their test and clarification.
here you can find one of the probably reason to have a wrong behavior in Collapse module
SACS Dynamic Response is a linear time-history solver so we can't directly add nonlinear elements like nonlinear springs into analysis. The way is done is through creating Collapse input and incremental loads using Dynamic Response and then run Collapse (Standard or Advanced) to include any nonlinearity including nonlinear springs
