Release Date |
28th April, 2026 |
Release Version |
13.01.00.024 |
This release adds support for Revit 2027.
The following versions of Autodesk Revit are supported by ISM Revit Plug-in 13.01:
iTwin Analytical Synchronizer 23.01.20 or newer required.
Release Date |
25th February, 2026 |
Release Version |
13.00.00.017 |
This release introduces support for Revit 2025 and Revit 2026.
Revit 2024 and earlier versions were based on .NET Framework, while starting with Revit 2025, Autodesk migrated the platform to .NET 8. This represented a fundamental platform shift rather than an incremental upgrade.
To ensure compatibility, the ISM Revit Plug-in and its underlying infrastructure underwent migration from .NET Framework to .NET 8. With this foundational work now complete, the ISM Revit Plug-in is fully compatible with Autodesk’s current platform and supports:
ISM Revit Plug-in in Revit 2026:
No functional changes are expected compared to previous versions. If you encounter any unexpected behavior, please contact our support team.
iTwin Analytical Synchronizer 23.01.18 or newer required.
