Release Date |
3rd February, 2026 |
Release Name |
ISM Revit Plug-in 12.13 |
Release Version |
12.13.00.012 |
This release introduces a new stud bracket configuration option, together with additional stability improvements.
Stud Formatting Settings:
The next major release, ISM Revit Plug-in 13.00, will enable support for Revit 2025 and Revit 2026.
Significant foundational platform work has been completed to enable this transition, and development is now in its final stage. Availability is expected soon.
Release Date |
28th November, 2025 |
Release Name |
ISM Revit Plug-in 12.12 |
Release Version |
12.12.00.017 |
This release includes various stability improvements and bug fixes.
Release Date |
19th September, 2025 |
Release Name |
ISM Revit Plug-in 12.11 |
Release Version |
12.11.00.011 |
This release includes routine security-related fixes to keep the plug-in safe and reliable, along with startup load improvements for a faster startup of the iTwin Services Add-in from Revit. No feature changes were made.
Release Date |
4th June, 2025 |
Release Name |
ISM Revit Plug-in 12.10 |
Release Version |
12.10.00.017 |
This update is primarily a robustness, security, and stability release.
Release Date |
6th March, 2025 |
Release Name |
ISM Revit Plug-in 12.09 |
Release Version |
12.09.01.001 |
Release Date |
11th December, 2024 |
Release Name |
ISM Revit Plug-in 12.08 |
Release Version |
12.08.00.032 |
Minor update with some bugfixes. Updated load resistance handling to be consistent between integrated products.
Release Date |
10th October, 2024 |
Release Name |
ISM Revit Plug-in 12.07 |
Release Version |
12.07.00.036 |
This release includes security improvements and bug fixes for mapping dialogs.
Release Date |
23rd July, 2024 |
Release Name |
ISM Revit Plug-in 12.06 |
Release Version |
12.06.00.054 |
The latest release of ISM Revit Plug-in adds support for multiple mapping selections and their manipulation in Load Case mapping and Material mapping workflows.
Additionally, partially mapped sections can now be distinguished with a special icon.
Release Date |
11th June, 2024 |
Release Name |
ISM Revit Plug-in 12.05.01 |
Release Version |
12.05.01.002 |
This release fixes an issue when the ISM Revit Plug-in is installed together with a 3rd party AVAIL Revit plugin.
Release Date |
29th April, 2024 |
Release Name |
ISM Revit Plug-in 12.05 |
Release Version |
12.05.00.026 |
Release Date |
19th February, 2024 |
Release Name |
ISM Revit Plug-in 12.04.01 |
Release Version |
12.04.01.001 |
Previously, shear stud values were inconsistently displayed, requiring rework to reconcile different display formats. They are now consistently displayed with square brackets for both beams with a single shear stud zone and beams with multiple shear stud zones. A comma-delimited format is adopted for beams with multiple shear stud zones.
Release Date |
8th February, 2024 |
Release Name |
ISM Revit Plug-in 12.04 |
Release Version |
12.04.00.021 |
Improved default materials mapping for older Revit families.
Fixes unexpected errors that can occur with older iTwin Services Add-in versions.
Release Date |
25th October, 2023 |
Release Name |
ISM Revit Plug-in 12.03.01 |
Release Version |
12.03.01.002 |
Fixes security issues in platform components.
Release Date |
12th October, 2023 |
Release Name |
ISM Revit Plug-in 12.03 |
Release Version |
12.03.00.020 |
Includes the ability to import tendons as 2D drawings into Revit.
This release includes robustness, stability improvements, and bug fixes.
Release Date |
24th July, 2023 |
Release Name |
ISM Revit Plug-in 12.02 |
Release Version |
12.02.00.007 |
Previously, some installations of REVIT 2022 reported an error when instantiating. This is now resolved.
Includes fixes for load objects and a crash in the settings dialog.
Release Date |
13th July, 2023 |
Release Name |
ISM Revit Plug-in 12.01 |
Release Version |
12.01.00.038 |
This version of ISM Revit Plugin now supports REVIT 2024 and ISM API 9.1
The ability to preview the selected ISM File repository has been restored in this version.
Shaft openings in REVIT punch a uniform opening across floors. Previously, certain arrangements of multiple shaft openings could cause them to be translated as floor members instead. This is now rectified.
The installation of the ISM Revit Plugin will automatically uninstall any previous versions that were installed. This version of ISM Revit Plugin can be run in Revit 2022, Revit 2023, and Revit 2024. iTwin Analytical Synchronizer automatically packages the ISM Revit Plugin.
Release Date |
7th May, 2023 |
Release Name |
ISM Revit Plug-in 12.00.01 |
Release Version |
12.00.01.008 |
An issue where the Dynamo plugin clashes with ISM Revit Plug-in and iTwin Services Add-in integration has been addressed.
Release Date |
25th April, 2023 |
Release Name |
ISM Revit Plug-in 12.00 |
Release Version |
12.00.00.038 |
This release integrates the iTwin Services Add-in panel inside Revit for a unified UX across all integrated products.
