Synchronization errors due to an issue in the Toolkit
The Toolkit Error category refers to a situation where there has been an internal error, resulting in synchronization errors. Here you will find an explanation and best practices for solving corrupt-related synchronization errors.
Table of Contents
Import Failure
Fatal: Revit_0028
Fatal Error message: There was an error on saving %d processed physical elements, likely due to running low on memory as the process was using <memory size> GB.
Issue:
Connector stopped unexpectedly while processing physical elements.
Cause:
Not enough memory was available to the connector.
Please contact Bentley support Bentley Support mentioning this error and they may be able to switch the processing to a machine with more available memory.
