gINT Multiple Downsize Library
Download here.
If your data is stored in a gINT SQL Server Enterprise Database, we’ve put together a “Multiple Downsize” Library File with a gINT Rule Add-in that can be used to “downsize” (export) projects from your gINT Enterprise Database to individual GPJ Project Files. This will then allow you to import them into OpenGround with the Batch Import Tool.
Please see this article for more information.
