Problem:
While using AutoPIPE for NC calculations for equation 10a. In this equation the allowable stress relies on the stress range reduction factor which is a function of the equivalent cycle count. How does AutoPIPE calculate the Sa value without this information or if it is taking cycle count into account in another way.
AutoPIPE's Stress summary for ASME NB has a column for number of cycles. However, when using ASME NC, the stress summary table does not have a column for number of cycles. Therefore, how does AutoPIPE evaluate the number of cycles for ASME NC analysis.
There are 2 possible answers to this question:
Answer #1:
Answer #2:
