EasyPower Supported Versions
EasyPower follows the Bentley Fixed Lifecycle Policy. This policy provides clearly defined lifecycle and support terms explaining how available technical support and maintenance services will change through the course of the application lifecycle.
For full details, refer to the official Bentley policy: https://www.bentley.com/support/bentley-lifecycle-policy/
EasyPower Support Schedule
Support Lifecycle Duration: A major version is supported until the end of the calendar year, 3 years after the original release date.
EasyPower Version Supported Until
EasyPower 2025 December 31, 2028
EasyPower 2024 December 31, 2027
EasyPower 11.0 December 31, 2026
EasyPower 10.6 December 31, 2025
EasyPower 10.5 December 31, 2025
EasyPower 10.4 December 31, 2025
Note: Versions released prior to 2023 fall under a transition provision and were supported through December 31, 2025.
