| Application | GeoStudio |
| Version | All versions |
| Primary Analysis | SEEP/W, TEMP/W, CTRAN/W, AIR/W |
| Date created | 25 September 2023 |
| Date modified | 25 September 2023 |
| Original author | Technical Support Group |
| Keywords | GeoStudio, Flux, Subdomain, mass and heat transfer, Graph |
The Draw Flux Section command was removed from GeoStudio 2018 and newer versions with the addition of the subdomain graphing feature.
The subdomain graphing feature in Draw Graph can be used to find the same result information as the flux section did in versions older than GeoStudio 2018. The Subdomain Graphing tutorial video illustrates how to use this feature.
