Offset functions in sensitivity/probabilistic analyses
Application GeoStudio
Version All Versions
Primary Analysis SLOPE/W
Date created 23 May 2025
Date modified 23 May 2025
Original author Technical Support Group
Keywords GeoStudio, offset, sensitivity, probabilistic analysis, parameter, range
Occurrence
SLOPE/W adopts offset functions in sensitivity/probabilistic analyses.
Resolution
In the Set Sensitivity/Probabilistic Parameters window, the range of a parameter is specified as the offset function from the specified value of the parameter. The advantage of using an offset is that the base value can be changed without altering the offset parameters. After the offset function is defined, the Modified Range will show the values of the parameter that will be used by the solver.
