Error Message: Failed to initialize synchronization without input files
Issue: There were no input files in the connection.
Cause: Each connection needs to have one or more files defined in the connection in order to be able to synchronize into an iModel.
Solution: Please ensure that there are valid files defined in this connection and try to run the synchronization again.
