Compatibility Chart: OpenUtilities Substation CONNECT Edition 2023 to 2025
Product(s):       OpenUtilities Substation CONNECT
Version(s):        23.00.00.82  to  25.00.00.57
Environment:    N/A
Area:                Installation_Configuration
Subarea:          Compatibility Chart
The purpose of this document is to indicate the compatibility of various software with OpenUtilities Substation CONNECT.  It is not intended to describe the compatibility of the various software with each other.  For example, certain versions of SQL Server may not be compatible with certain operating systems.  Always check the documentation of the different software involved.
OpenUtilities Substation Version → CONNECT 2023 (23.00.00.82) CONNECT 2023 U1 (23.00.01.67) CONNECT 2024 (24.00.00.82) CONNECT 2025 (25.00.00.57)
Operating System ↓
Windows 11 (64-bit) Yes Yes Yes Yes
Windows 10 (64-bit) Yes Yes Yes Yes
Windows 8.1 (64-bit) No No No No
Windows Server 2025 (64-bit) No No No Yes
Windows Server 2022 (64-bit) Yes Yes Yes Yes
Windows Server 2019 (64-bit) Yes Yes Yes Yes
Windows Server 2016 (64-bit) No No No No
Database Software ↓
SQL Server 2022 (Including Express) Yes Yes Yes Yes
SQL Server 2019 (Including Express) Yes Yes Yes Yes
SQL Server 2017 (Including Express) Yes Yes Yes Yes
SQL Server 2016 (Including Express) Yes Yes Yes Yes
ProjectWise Integration ↓
ProjectWise 2024 24.00.05.8008 No No Yes Yes
ProjectWise 2024 24.00.03.8003 No No Yes Yes
ProjectWise 2024 24.00.02.8008 No No Yes Yes
ProjectWise 2024 24.00.01.8001 No No Yes Yes
ProjectWise 2024 24.00.00.5502 No Yes Yes Yes
ProjectWise 2023 23.06.03.12 No Yes Yes Yes
ProjectWise 2023 23.06.00.30 No Yes Yes Yes
ProjectWise 2023 23.06.00.15 No Yes Yes Yes
ProjectWise 2023 23.05.00.11 No Yes Yes Yes
ProjectWise CONNECT 10.00.03.453 Yes Yes Yes Yes
ProjectWise CONNECT 10.00.03.434 Yes Yes Yes Yes
ProjectWise CONNECT 10.00.03.334
ProjectWise CONNECT 10.00.03.329
ProjectWise CONNECT 10.00.03.299 Yes Yes Yes Yes
ProjectWise CONNECT 10.00.03.280
ProjectWise CONNECT 10.00.03.271
ProjectWise CONNECT 10.00.03.262
Microsoft Office 365 Version ↓
Microsoft 365 (Version 2408) 17928.20216   Yes Yes Yes
Microsoft 365 (Version 2407) 17830.20232   Yes Yes Yes
Microsoft 365 (Version 2403) 17425.20176   Yes
Microsoft 365 (Version 2402) 17328.20282   Yes Yes Yes
Microsoft 365 (Version 2401) 17231.20304   Yes
Microsoft 365 (Version 2309) 16827.20166 Yes
Microsoft 365 (Version 2308) 16731.20316 Yes Yes Yes Yes
Microsoft 365 (Version 2307) 16626.20222 Yes
Microsoft 365 (Version 2303) 16227.20318 Yes
Microsoft 365 (Version 2302) 16130.20500 Yes Yes
Microsoft 365 (Version 2211) 15831.20208
Microsoft 365 (Version 2210) 15726.20262 Yes
Microsoft 365 (Version 2209) 15629.20298 Yes
Microsoft 365 (Version 2208) 15601.20378 No No No No
CONNECT ↓
PowerPlatform 23.00.01.329 23.00.02.464 24.0.1.418 25.0.1.407
CONNECT Client 23.00.00.10 23.00.00.10 24.01.00.23 25.00.01.04
CONNECT Advisor N/A N/A N/A N/A
License 23.00.00.12 23.00.01.25 24.1.0.14 25.0.1.3
DB version 10.0.33 10.0.33 10.0.33 10.0.33
DB Sub version 7 7 9 9
Important Notes
Important Links
