iTwin Analytical Synchronizer 23.01.*
Table of Contents
iTwin Analytical Synchronizer 23.01.20
Release Date
28th April, 2026
Release Name
Release Version
23.01.20.021
iTwin Services Add-in
A black and white signAI-generated content may be incorrect.26.01.00.71
ISM Revit™ Plug-in
A black and white signAI-generated content may be incorrect.A black and white signAI-generated content may be incorrect.13.01.00.19
12.14.00.1
ISM RAM Structural System Plug-in
A black and white signAI-generated content may be incorrect.01.06.00.14
Supported ISM API Versions
8.0, 8.1, 9.0, 9.1, 9.2, 9.3
Revit 2027 support
This release adds support for Revit 2027 through a new version of ISM Revit Plug-in.
Legacy ISM Revit Plug-in support
This release includes an option to install a separate legacy version of ISM Revit Plug-in. The user can now have two different ISM Revit Plug-in versions for wider Revit version support.
Maintenance Patch
This update also includes robustness, security and stability improvements.
iTwin Analytical Synchronizer 23.01.19
Release Date
27th March, 2026
Release Name
Release Version
23.01.19.012
26.00.00.074
ISM Revit™ Plug-in
13.00.00.017
01.05.00.023
Maintenance Patch
This update is primarily a robustness, security and stability release.
Installer Layout Fix
This release includes a fix for the installer when running in layout mode.
iTwin Analytical Synchronizer 23.01.18
Release Date
25th February, 2026
Release Name
Release Version
23.01.18.014
26.00.00.074
ISM Revit™ Plug-in
A black and white signAI-generated content may be incorrect.13.00.00.017
01.05.00.023
Maintenance Patch
Revit 2025 and Revit 2026 Support
This version of iTwin Analytical Synchronizer includes ISM Revit Plug-in that introduces support for Revit 2025 and Revit 2026.
iTwin Analytical Synchronizer 23.01.17
Release Date
13th February, 2026
Release Name
Release Version
23.01.17.038
26.00.00.074
ISM Revit™ Plug-in
A black and white signAI-generated content may be incorrect.12.13.00.012
A black and white signAI-generated content may be incorrect.01.05.00.023
Maintenance Patch
.NET 8 Compatibility
Architectural changes have been made in this version of iTwin Analytical Synchronizer that will allow the next version of ISM Revit Plug-in (13.0) to enable support for Revit 2025 and Revit 2026.
iTwin Analytical Synchronizer 23.01.16
Release Date
18th December, 2025
Release Name
Release Version
23.01.16.025
A black and white signAI-generated content may be incorrect.26.00.00.074
ISM Revit™ Plug-in
A black and white signAI-generated content may be incorrect.12.12.00.017
A black and white signAI-generated content may be incorrect.01.04.00.017
Maintenance Patch
Optional IFC Functionality
Due to impediments preventing security fixes for IFC workflows, IFC functionality has been made optional when installing iTwin Analytical Synchronizer. This feature is disabled by default.
iTwin Analytical Synchronizer 23.01.15
Release Date
26th September, 2025
Release Name
Release Version
23.01.15.015
A black and white signAI-generated content may be incorrect.25.01.01.009
ISM Revit™ Plug-in
A black and white signAI-generated content may be incorrect.12.11.00.011
A black and white signAI-generated content may be incorrect.01.03.00.031
Maintenance Patch
Wall Graphics
Graphics for cylindrical walls have been extended. Now walls whose boundary (representing the top or bottom edge of the wall) is defined by multiple connected line segments will generate full graphics.
A set of curved doorsAI-generated content may be incorrect.
iTwin Analytical Synchronizer 23.01.14
Release Date
1st August, 2025
Release Name
Release Version
23.01.14.025
A black and white signAI-generated content may be incorrect.25.01.00.058
ISM Revit™ Plug-in
12.10.00.017
A black and white signAI-generated content may be incorrect.01.02.00.09
Maintenance Patch
Workflows
Before this version, Workflows window and Settings context tab would not always show up during Change Management. This issue has been fixed with this release.
A screenshot of a computerAI-generated content may be incorrect.
iTwin Analytical Synchronizer 23.01.13
Release Date
12th June, 2025
Release Name
Release Version
23.01.13.028
A black and white signAI-generated content may be incorrect.25.00.02.001
ISM Revit™ Plug-in
A black and white signAI-generated content may be incorrect.12.10.00.017
A black and white signAI-generated content may be incorrect.01.01.00.016
Maintenance Patch
Feature Subtraction Graphics
Before this release, iTwin Analytical Synchronizer contained a bug where Feature Subtractions would not show up in the Model viewer. This issue has been fixed, and the Feature Subtractions once again show up when opening a repository in iTwin Analytical Synchronizer.
iTwin Analytical Synchronizer 23.01.12
Release Date
8th May, 2025
Release Name
Release Version
23.01.12.018
A black and white signAI-generated content may be incorrect.25.00.00.030
ISM Revit™ Plug-in
12.09.01.001
A black and white signAI-generated content may be incorrect.01.00.00.017
Maintenance Patch
This release of iTwin Analytical Synchronizer bundles a new ISM RAM Structural System Plug-in. This plug-in separates out interoperability features away from RAM Structural System. This will allow more robust maintenance for RAM Structural System interoperability.
iTwin Analytical Synchronizer 23.01.11
Release Date
24th March, 2025
Release Name
Release Version
23.01.11.022
A black and white signAI-generated content may be incorrect.24.03.01.002
ISM Revit™ Plug-in
A black and white signAI-generated content may be incorrect.12.09.01.001
Maintenance Patch
Workflows Stability Fixes
This update fixes an issue where ISM Workflows would sometimes fail to automate object Rejection.
iTwin Analytical Synchronizer 23.01.10
Release Date
3rd February, 2025
Release Name
Release Version
23.01.10.050
A black and white signAI-generated content may be incorrect.24.02.00.039
ISM Revit™ Plug-in
12.07.00.036
Maintenance Patch
iTwin Analytical Synchronizer 23.01.09
Release Date
14th October, 2024
Release Name
Release Version
23.01.09.031
A black and white signAI-generated content may be incorrect.24.01.00.040
ISM Revit™ Plug-in
A black and white signAI-generated content may be incorrect.12.07.00.036
Maintenance Patch
iTwin Analytical Synchronizer 23.01.08
Release Date
26th July, 2024
Release Name
Release Version
23.01.08.037
A black and white signAI-generated content may be incorrect.24.00.01.001
ISM Revit™ Plug-in
A black and white signAI-generated content may be incorrect.12.06.00.054
Maintenance Patch
Revit™
The latest release of ISM Revit™ Plug-in adds support for multiple mappings selection and their manipulation in Load Case mapping and Material mapping workflows.
A screenshot of a computerAI-generated content may be incorrect.A screenshot of a computerAI-generated content may be incorrect.
Additionally, partially mapped sections can now be distinguished with a special icon.
For Revit™ users, only one download and installation of iTwin Analytical Synchronizer is required, the latest plugin to support Revit™ is already built in.
iTwin Analytical Synchronizer 23.01.07
Release Date
17th June, 2024
Release Name
Release Version
23.01.07.033
03.01.01.002
ISM Revit™ Plug-in
12.05.00.026
Maintenance Patch
iTwin Analytical Synchronizer 23.01.06
Release Date
21st May, 2024
Release Name
Release Version
23.01.06.044
A black and white signAI-generated content may be incorrect.03.01.01.002
ISM Revit™ Plug-in
A black and white signAI-generated content may be incorrect.12.05.00.026
A black and white signAI-generated content may be incorrect.8.0, 8.1, 9.0, 9.1, 9.2, 9.3
Notable changes in this release of iTwin Analytical Synchronizer include the continuing broadening of object types supported for Bentley Infrastructure Cloud.
Referencing Load Combinations in Analysis and Design Results is now supported in Bentley Infrastructure Cloud.
API Supports
This version of iTwin Analytical Synchronizer introduces ISM API 9.3 which adds support for Load Combinations in Analysis and Design Results.
As with general practice, API releases are supported for at least three years. Currently ISM API 8.0, 8.1, 9.0, 9.1, 9.2 and 9.3 are supported.
iTwin Analytical Synchronizer 23.01.05
Release Date
27th March, 2024
Release Name
Release Version
23.01.05.008
03.01.02.024
ISM Revit™ Plug-in
A black and white signAI-generated content may be incorrect.12.04.00.021
Maintenance Patch
This update is primarily a robustness and stability release.
iTwin Analytical Synchronizer 23.01.04
Release Date
22nd of February, 2024
Release Name
Release Version
23.01.04.062
A black and white signAI-generated content may be incorrect.03.01.02.024
ISM Revit™ Plug-in
A black and white signAI-generated content may be incorrect.12.04.01.001
Notable changes in this release of iTwin Analytical Synchronizer include the continuing broadening of object types supported for Bentley Infrastructure Cloud as well as improvements in Revit™ material mappings.
Steel Decks and Joists are now fully supported on Bentley Infrastructure Cloud. This enhancement particularly benefits RAM Structural System users.
Revit™
- Improved default materials mapping for older REVIT™ families.
- Previously, shear stud values were inconsistently displayed, requiring rework to reconcile different display formats. They are now consistently displayed with square brackets for both beams with a single shear stud zone and beams with multiple shear stud zones. A comma delimited format is adopted for beams with multiple shear stud zones.
Cloud Synchronization
 Across all host application's in-product cloud synchronization operation, status messaging has been grouped and streamlined.
File Synchronization
 Added ability to establish subsequent new Sync.
Once an existing sync is established, select or establish a new sync by clicking on the blue hyperlink:
Previously only the initial "push" provides the New Sync button, whereas now the New sync button is ever present.
iTwin Analytical Synchronizer 23.01.03
Release Date
15th December, 2023
Release Name
Release Version
23.01.03.042
A black and white signAI-generated content may be incorrect.03.00.00.026
ISM Revit™ Plug-in
12.03.01.002
Notable changes in this release of iTwin Analytical Synchronizer include the addition of Tapered Walls, Load Combinations, and support for Tapered Members.
REVIT™ 2024
This update of iTwin Analytical Synchronizer incorporates the latest plugin to support REVIT™ 2024. The installed component is backwards compatible with REVIT™ 2022 and REVIT™ 2023.
For Revit™ users, only one download and installation of iTwin Analytical Synchronizer is required, the latest plugin to support REVIT™ is already built in.
Tapered Walls
This update of iTwin Analytical Synchronizer includes API updates to support Tapered Wall object types. Previously, only walls of uniform thickness were supported. Now, retaining walls and in particular Water Treatment Structures with wall thicknesses that vary along the height of the wall can be represented and benefit from this data type addition.
Tapered Members
This update of iTwin Analytical Synchronizer includes update to represent Tapered Members in cloud workflows. This addition of Tapered members particularly benefits SACS/Offshore interactions with Bentley Infrastructure Cloud. Previously models with tapered members can only be viewed via File based workflows. Now, both File and Cloud base synchronization workflows involving models with Tapered members can be viewed in both iTwin Analytical Synchronizer and the web browser respectively.
Load Combinations
This update of iTwin Analytical Synchronizer includes API updates to support Load Combinations as first-class citizens (for Cloud based workflows). Previously, only primary load cases were supported, and required user’s manual duplication between applications.
Workflows involving multiple analysis applications with hundreds or thousands of load combinations (manual or auto generated) will benefit from load combinations support, in that an analysis application downstream can reuse the load combinations defined in an upstream application without manual reentry. With this enhancement, in addition to the underlying structural design intent, loads, load cases and load combinations will all be transferred via cloud-based workflows.
One example workflow that would benefit involves in-place structure and sea transportation structures utilizing both STAAD, SACS and iTwin Analytical Synchronizer where it is common practice to involve large number of load combinations.
iTwin Analytical Synchronizer 23.01.02
Release Date
11th October, 2023
Release Name
Release Version
23.01.02.064
A black and white signAI-generated content may be incorrect.02.06.01.001
ISM Revit™ Plug-in
A black and white signAI-generated content may be incorrect.12.03.01.002
Maintenance Patch
API Supports
This version of iTwin Analytical Synchronizer introduces ISM API 9.2. This version of the ISM API adds support for Load Combinations (only in Cloud workflows), Tapered Surface Member Regions and some utilities for using Tendons.
As with general practice, API releases are supported for at least three years. Currently ISM API 8.0, 8.1, 9.1 and 9.2 are supported.
iTwin Analytical Synchronizer 23.01.01
Release Date
1st September, 2023
Release Name
Release Version
23.01.01.056
A black and white signAI-generated content may be incorrect.02.05.00.030
ISM Revit™ Plug-in
A black and white signAI-generated content may be incorrect.12.02.00.007
8.0, 8.1, 9.0, 9.1
REVIT™ 2024
This update of iTwin Analytical Synchronizer incorporates the latest plugin to support REVIT 2024.
RAM Concept 2023
- Reduced wait times of Cloud workflow operations (Push/Pull). Typical models experience can now be processed approximately 10x faster. Larger, complicated models with more intricate tendon layouts are between 20x to 25x faster to process.
- Improved tendon graphics for iTwins originating from RAM Concept. Including the display of tendon anchors.
- It is now more intuitive to visualize the interplay between tendons, anchors and surrounding concrete elements in Analytical Design Review
Security, Maintenance and Stability fixes
This update also includes many security and stability fixes. As with general practice, API releases are supported for at least three years. Currently ISM API 8.0, 8.1, and 9.1 are supported.
iTwin Analytical Synchronizer 23.01.00
Release Date
15th June, 2023
Release Name
Release Version
23.01.00.119
A black and white signAI-generated content may be incorrect.02.04.00.042
ISM Revit™ Plug-in
A black and white signAI-generated content may be incorrect.12.01.00.008
8.0, 8.1, 9.0, 9.1
REVIT™
This update of iTwin Analytical Synchronizer resolves a clash in assemblies between external add-ins (such as REVIT™ Dynamo) and the iTwin Services experience within REVIT™. The resolution for the aforementioned involves the iTwin Services Sidebar to be "undocked" in REVIT™.
The iTwin Services sidebar is present in all iTwin Analytical applications. This update improves the about screen with more useful information including ability to quickly ascertain the relevant API versions and access to Logs. This feature helps our support staff to diagnose faults and crashes.
Within Tendon Visualization in Analytical Design Review, the selected tendon properties pane is now more intuitive to use.
  1. Select Tendon Visualization mode.
  2. Select Tendon On screen in the 3D viewer.
  3. [New] Tendon properties pane showing the properties of the tendon segments. Properties are grouped whenever possible.
Bug fixes
This update also includes many security and stability fixes. As with general practice, API releases are supported for at least 3 years. Currently ISM API 8.0, 8.1, and 9.1 are supported.
