Installation Guide: STAAD Foundation Advanced 2025 (v25.00.01)
Download Instructions
Installation files for current and past STAAD Foundation Advanced releases can be downloaded from the Bentley Software Download page. After signing-in, the STAAD Foundation Advanced installers can be located by selecting STAAD in the Brand menu and clicking Apply or searching for STAAD Foundation in the Product Search box.
This version of STAAD Foundation Advanced can also be installed through the CONNECTION Client update service or through the Structural WorkSuite Hub.
Two different versions or it's updates can be installed side by side – viz., version 24 and 25. Thus, this version of STAAD Foundation Advanced can be installed concurrently with any of the previous versions.
Installation instructions
Please note that this tutorial has been created using a beta version of the installer. Thus, we strike through the last digits that appear after 25.00.01 in the version number. The numbers that you will see in its place will be the ones that will correspond to the released version number.
  1. Please right click on “Setup_StaadFoundationAdvancedx64_25.00.01.***.exe” and select “Run as administrator”.
A screenshot of a computerAI-generated content may be incorrect.
Fig.1
  1. The following window appears. Please select “Yes”.
Fig.2
  1. You will see that the setup is now initialized, and the following window appears. Please follow the steps as mentioned in the figure below (figure # 3):
Fig.3
  1. Now, finally the following window is displayed showing all the components of installation. Please press the “Install” button to start the installation process.
Fig.4
  1. Once the installation process is complete, the following window will be displayed. Please press the “Finish” button to get out of the installation mode.
Fig.5
