Why is there no impact on fatigue calculations when changing the thickness in AD 2000?
Fatigue analysis is performed according to AD 2000-Merkblätter (03-2022) S 1.
Calculation Logic:
Code Reference:
Avoidance:
To make thickness affect fatigue calculations:
Flowchart: Selection of Clause 4.3 for Load Cycle Determination
⬇️Step 1: Identify the component type.
⬇️Step 2: Check if the component is welded.
⬇️Step 3: Verify temperature condition.
⬇️Step 4: Check wall thickness (sₑ).
⬇️Step 5: Check stress factor (η).
⬇️✅ Apply Clause 4.3
Use equations (7) and (8) to determine allowable load cycles:
Bentley AutoPIPE Vessel
Support Solutions and FAQ's
Error Messages
Warning Messages
Calculations
