Video: Explaining and Modifying the Default Node Height of an ORD Node Feature
Product(s): OpenRoads Designer Connect Edition
Version(s): 2024+
Area:  Drainage & Utilities
Video by:  Jordan Belcher
This video explains how the Default Node Height of a Feature Definition is applied when placing a node and how it interacts with the 3D cells assigned to the Feature Definition. Review this article for further explanation.
