Problem:
AutoPIPE API, throws internal error (E0) and fails to open AutoPIPE models that are generated through PCF.
Steps to Repeat:
- Use PCF Translator to convert .PCF file into an AutoPIPE .NTL file.
- Open *.NTL file with AutoPIPE which converts it into a *.DAT file.
- Use AutoPIPE API to open the generated *.DAT file.
- Notice that model fails to open and the following error is shown:
There is no solution or workaround at this time. This has been logged (1876798) and will be investigated.
