ProStructures 2024.3 (24.00.03.34)
The ProStructures Product team is pleased to announce the availability of ProStructures 2024.3 (24.00.03.34) through the Bentley CONNECT Center, Software Downloads portal, or the desktop CONNECTION Client.
This version incorporates many user-requested fixes and enhancements. It also includes updates from MicroStation 2024.2.
What's New Highlights for ProStructures 2024.3
General Updates:
ProStructures 2024.3 (24.00.03.34) will update any version of ProStructures 2024 installed.
Integrated MicroStation 2024
It includes updates from MicroStation 2024.2, MicroStation version is 24.0.2.392. More information on the new functionality in MicroStation 2024.2 can be found in the ProStructures Help and Readme.
Security Improvements
This release also includes the latest ProStructures and MicroStation security improvements. The details will be found in our advisory page website located in our Trust Center here https://www.bentley.com/trust-center
Usability and Productivity Enhancements:
Usability and the overall user experience in ProStructures is a key focus for our team. The following improvements were implemented:
IFC Improvements: Improvements have been made in the IFC output to include cells.
Beam/Beam Stiffner Connections: Radial cope placement is introduced for Beam/Beam Stiffener connections.
View Frame Improvements: There will be consistent placement of 2D details when the view frame is in the drawing.
Bolts Generation: Improved and consistent generation of bolts.
Update via CONNECTION Client:
If you have ProStructures 2024 already installed on your computer, then ProStructures 2024.3 will be advertised as an update from the CONNECTION Client. You can incrementally download and install ProStructures 2024.3 from the CONNECTION Client. It will update and replace ProStructures 2024.
If you have any earlier version of ProStructures CONNECT Edition or 2023 already installed on your computer, you can download and install ProStructures 2024.3 from the CONNECTION Client. It will install as a separate instance of ProStructures with the root directories ..\Program Files\Bentley\ProStructures 2024 and ..\ProgramData\Bentley\ProStructures 2024. Sign into the CONNECTION Client to view and apply your application updates. If needed, please refer to the CONNECTION Client help for more information on installing the update.
Get ProStructures 2024.3:
Open https://softwaredownloads.bentley.com/en/ProductDetails/2270 in any browser and sign in.
Click Download to download ProStructures 2024 x64 version 24.00.03.34.
Note: Important installation requirements and notices are found in the ReadMe.
If you have any additional questions or need guidance, please contact Bentley Support or a member of your account team.
