.MKE/.MKI Files
STEP 1 - Add Policy File and common Environment Macros/Variables |
STEP 2 - Replace ALL instances of "genSrc" with "o" in your MKE and MKI files |
NOTE: TYPICAL - For Multiple Instances/Build Contexts
STEP 3 - Ensure correct location of cincapnd.mki |
STEP 4 - Update Linker Macros |
STEP 5 Update DLM_LIBRARY_FILES (See Stop 4 From/To items as a Starting Point) |
Renamed Library Names
STEP 6 Ensure correct location of dlmlink.mki |
