AutoPIPE's calculated SIF values are inconsistent with manual results.
Scenario 1:
How does AutoPIPE determine the in-plane run SIF for a Sketch 2.6 integrally reinforced welded branch fitting, given that the result does not align with manually calculated values?
AutoPIPE SIF Value: 3.038
Manually Calculated SIF Value: 3.427
Answer: AutoPIPE calculates the in-plane run SIF for Sketch 2.6 based on the rules and constraints defined in the ASME B31J code, specifically referencing Notes (1), (7), and (10) applicable to this sketch.
Refer to the Note (7) as shown below:
Note (7) outlines the bounding conditions for SIF and flexibility factors across various sketches:
For Sketches 2.1, 2.2, 2.4, 2.5, and 2.6:
AutoPIPE Report: Shows the computed SIF value of 3.038.
Manual calculations: Indicates a higher SIF of 3.427.
AutoPIPE’s SIF calculation for Sketch 2.6 adheres to ASME B31J Note (7), which enforces upper and lower bounds based on other sketches. The capped value ensures that the SIF does not exceed the reference from Sketch 2.3 (3.038) , even if manual calculations suggest a higher value (3.427).
Support Solutions and FAQ's in AutoPIPE
Piping Code Calculations - AutoPIPE
ASME B31J Code Calculation Issues
