Q:
I have been trying to run SACS file via external command like python using Analysis engine option. But found it is not accessible. Before contacting my IT Network team, need to know whether using Analysis engine option attracts additional charges or licensing number.
R:
The SACS Analysis Engine only utilizes the licenses required for performing analysis and does not require any additional licenses. For further details, you may refer to the article provided.
