PLAXIS Monopile Designer 2025.1.3 (25.1.3.5) contains the following improvements and updates compared to PLAXIS Monopile Designer 2024.3:
Compatibility with PLAXIS’ new calculation input and results database
PLAXIS Monopile Designer 2025.1.3 is fully compatible with the new calculation input and results database included in the PLAXIS 3D 2025.1.3 PLAXIS 3D 2025.1.2 and and PLAXIS 3D 2025.1.0.
Other changes and improvements
- Upgraded Python environment to Python 3.12.11 to keep up with the latest security improvements.
- Fixed issue where the 1D analysis might not reach the target displacement in very loose sands.
- Support for Academic licences.
Fixed issues
A large number of issues have been addressed, including:
- [1473334] Monopile Designer now allows entering the parameters c' and m for sand.
- [1496645] Fixed an issue where the active cell lost its selection after data entry.
- [1496660] In the Calibration Matrix, the symbol indicating that the model is not generated yet (blue triangle) is visible again for newly added soil profile data sets (GeoDS).
- [1533385] Resolved a startup issue when checking the Monopile Designer license.
- [1798766] Monopile Designer no longer crashes when reopening a previously closed project.
Download links
You can update to the latest version using the CONNECTION Client, or download the installer via Bentley System's Software downloads page.
