PLAXIS 3D 2025.1 Release Notes
New in PLAXIS 3D 2025.1.3
Release: May 2026
PLAXIS 3D 2025.1.3 (25.1.3.5) contains the following improvements and updates compared to PLAXIS 3D 2024.3:
New features
New calculation input and results database
The application’s calculation input and calculated results as well as its storage have been redesigned, resulting in many improvements and better consistency of the PLAXIS data. Changes span across calculation input, results calculation, results derivation, curve performance and results availability. Notable changes include:
Compatibility notes: Due to this major change, when opening older projects, they will be converted and saved with a _converted suffix in the 2025.1 format and require remeshing and recalculation. To ease the transition to the new release and not block ongoing projects, side-by-side installation with the previous releases of PLAXIS is supported.
Be aware that earlier versions of PLAXIS will not be able to open files saved in PLAXIS 3D 2025.1.
Other changes and improvements
Fixed issues
A large number of issues have been addressed, including:
Download links
You can update to the latest version using the CONNECTION Client or download the installer via Bentley System's Software downloads.
