【背景描述】
在结构分析中,风荷载的强度会随高度变化(比如高处风速更大,风荷载更强)。我们需要通过两个步骤完成风荷载的基础设置:
| 函数名 | 作用 | 参数说明 |
AddWindDefinition |
创建风荷载定义 |
[input] TypeNo: Wind Definition Type number ID [input] TypeName: Wind Definition name |
AddWindIntensity |
风荷载定义添加 “高度 - 强度数据” |
[Input] TypeNo: Wind Definition Type number ID [Input] Intensity: Intensity value (Unit: Force/Length^2) [Input] Height: Height value (Unit: Length) |
Sample VBA Syntax:
Set objOpenStaad = GetObject(, "StaadPro.OpenSTAAD")
Dim TypeNo As Long
Dim TypeName As String
Dim intensity(1) As Double
Dim height(1) As Double
TypeNo = 1
TypeName = "WIND 1"
objOpenStaad.Load.AddWindDefinition TypeNo, TypeName
intensity(0) = 1.24
intensity(1) = 1.41
height(0) = 10
height(1) = 15
objOpenStaad.Load.AddWindIntensity TypeNo, intensity, height
