Verification - PWP Response of an Unsaturated 1D Column
Application GeoStudio
Version Latest version
Primary Analysis SIGMA/W
Keywords GeoStudio, SIGMA/W, hydro-mechanical, unsaturated, response, saturated, soil, consolidation, saturation, stress-water, pore water, pressure, loading, unloading
Introduction
The hydro-mechanical response of an unsaturated soil is more complex than a saturated soil because of the presence of air and water in the pore space. The SIGMA/W consolidation formulation gives consideration to the degree of saturation in the unsaturated zone for calculating stress-water coupling term. As such, the pore-water pressure due to loading depends on the volumetric water content function for an unsaturated soil.
This examples demonstrates the pore-water pressure response of an unsaturated soil subjected to loading and unloading at the ground surface using a consolidation analysis.
Downloads
See also
Examples - SIGMA/W - Overview    [Examples]
SIGMA/W Tutorial    [Examples]
Settlement due to Pumping    [Examples]
Heave due to Infiltration    [Examples]
