Resolved Issues
The following issues have been corrected and/or added to the OpenCities Map 2025. Compare the reference numbers from your service request below to determine whether a given issue has been resolved in this release.
Version 25.00.01.40
| Reference | Summary Description | Keywords |
| 1032242 | Unexpected message when dropping an XFM polygon collection. | XFM |
| 1100916 | Some elements are shifting in the PDF output. | Printing |
| 1107265 | In the Map session, display issue with the unpinned dialog box. | User Interface |
| 1232833 | Removed import .IFC files in OpenCities Map PowerView. | Import - Export |
| 1356002 | Fixed an incorrect connection to a WFS server. | Database |
| 1479185 | Reset the XFM text feature to View Dependent after XFM editing. | XFM |
| 1488284 | OpenCities Map should save WorkSet properties to .dgnws files. | Map Configuration |
| 1491742 | Improved post changes when closing the file with PostGIS and SQL Server. | Database |
| 1542128 | Allowed posting to SQL Server with a custom coordinate system. | Database |
| 1556940 | Permission to use the read-only "_dlgprefs.xml" file. | Map Configuration |
| 1568549 | MapUltimate for Finland: Allow KTJ import in batch mode. | XFM |
| 1570260 | PostGIS spatial query using fences placed by shape. | Database |
| 1583260 | Add Workset selection in Insert Cell Placement Metadata dialog. | XFM |
| 1601978 | Implementation of Veracode static analysis in OpenCities Map. | Security |
| 1620978 | Enabled FME 2025 in OpenCities Map 2025. | Import - Export |
| 1624894 | Permission to place or promote point cells with item types attached to the cell model. | XFM |
| 1639511 | Improved fence-to-file clipping results in OpenCities Map. | XFM |
| 1678427 | Enabled Google 2D in OpenCities Map. | Google 2D |
| 1682850 | Triggers the loading of MSPyMstnPlatform on MS Python in Map Advanced. | API / SDK |
| 1687483 | Data Browser: Locate or highlight with the reference model. | Analyze |
| 1701196 | Allowed the drop of Item Types from the XFM Polygon feature. | XFM |
| 1702982 | Added a refresh event handler to the session/authentication token. | Google 2D |
| 1703007 | Added the Google 3D photorealistic layer in OCM as a technology preview. | Google 3D |
| 1704263 | OpenCities Map - Python Manager | API / SDK |
| 1708197 | Detected an error when connecting to a PostGIS spatial database. | Database |
| 1724959 | Added functionality for the GeoSpatial Administrator to connect to OAuth2 authenticated feature services. | Database |
| 1727550 | Connecting to a WFS URL is too long. | Database |
| 1744493 | A level-specific variables defined in the GSA. | Map Configuration |
| 1745457 | Improved register spatial features. | GSA |
