Bing Map Imagery will not display. How to resolve in OpenCivil Designer
Product(s):
OpenRoads, Microstation
Version(s):
10.01.XX.XX and greater
Area:
Model Detailing
Problem:
Bing maps backgrounds is not working correctly unless using a raster attachment. The following requirements have been met:
1.) Internet Connection
2.) Coordinate System defined in the DGN file
3.) Logged into the CONNECTION client (which is up-to-date).
But the Bing command on each view window and in the ribbon still do not work.
This issue is related to a critical change that occurred recently on Microsoft's end (Announcing Bing Maps for Enterprise Platform End of Life - Microsoft Q&A). Many User's were experiencing this problem after Microsoft deprecated the Bing Maps system starting on June 30th, 2025.
If a user has their own Bing Maps API key, only raster attachments will work—Bentley’s built-in Bing Maps will not load.
To fix this, remove the configuration variable MS_RASTER_BINGMAP_KEY.
Restart the application and Bing Maps should now be working.
In the 2025 product rollout, Bing Maps will be replaced with Google Maps. For more information on this, please refer to the links below.
New and Changed in MicroStation 2025
MicroStation - Deprecation Notice: Bing Maps for Enterprise. Welcoming Google Maps to MicroStation! - Communities
