| Products: | WaterGEMS, WaterCAD, HAMMER |
| Version(s) | 24.00.03.22 |
| Area: | Installation |
A new version of OpenFlows Water 2024, which consists of WaterGEMS, WaterCAD, and HAMMER, has been released.
The new release supports integration with AutoCAD 2026 and MicroStation 2025.
Raster files are now a supported source file type to import elevation data using TRex.
This was previously supported in the ArcGIS Pro integrated versions, but is now available in Standalone. More information on using TRex can be found here: Using Terrain Extractor (TRex) to assign elevations.
Compatible Operating Systems:
Supported Platforms:
ProjectWise integration:
Support for ProjectWise 2024 and 2023 are also included.
Older models can be opened in this version of WaterGEMS, WaterCAD, and HAMMER.
Models saved in the 2024 versions can still be opened in 2023 versions.
See: Model backward / forward compatibility
As with all new versions, this release includes fixes to various user-reported issues from the previous release, providing an overall more stable experience.
WaterGEMS and WaterCAD TechNotes and FAQs
