How To Add Flow Arror in Isometric
Product(s):
OpenPlant Isometrics Manager CE
Version(s):
2024.2 & above
Environment:
Windows 11 (64 bit)
Area:
General
Subarea:
General
Original Author:
Joseph Gelacio, Bentley Global Technical Support Group
In OpenPlant Isometric Manager, user want to show the direction of the flow as described below:
A yellow arrow pointing to a black background
AI-generated content may be incorrect.
1. Launch OpenPlant Modeler, and got to Piping>Generic>Notes, select flow arrow and manually place in the pipe
A screenshot of a computer
2. Generate the Isometric again, flow arrow should show up on the Isometric output
A line with a red circle in the middle
OpenPlant Communities Resource Center
Comments or Corrections?
Bentley's Global Technical Support group requests that you please confine any comments you have on this Knowledge Base Article entry to Forum section. THANK YOU!
