While learning to use AutoPIPE's API commands, review the following examples for correct syntax:
Notes:
- All examples shown below assumes that the model is currently in the same folder as the Python's API script file.
- A copy of the files from AutoPIPE's example folder has been copied to the same folder as the Python API scripts
- C:\ProgramData\Bentley\AutoPIPE xxxx\Examples
- Additional examples of Python's API scripts can be seen here
- C:\Program Files\Bentley\AutoPIPE xxxx\DataAPI\Example Scripts
- For detail explanation of AutoPIPE API commands, open index.html located on your computer:
- C:\Program Files\Bentley\AutoPIPE xxxx\DataAPI\Docs\html\
Query Data
Back to Top
Modify Data
Back to Top
Remove Data
Back to Top
