| Application | GeoStudio |
| Version | Latest version |
| Primary Analysis | SEEP/W |
| Keywords | GeoStudio, SEEP/W, uplift pressure, erosion, flow regime, upstream, embankment |
Many geotechnical engineering problems include the flow of water around a cut-off, which is installed to reduce the up-lift pressure on the dam and reduce the possibility of internal erosion along the soil-structure contact.
This example will illustrate the ability of SEEP/W to simulate the flow regime of a soil, where a cut-off exists below the upstream side of an embankment.
