Model Tree
Model Tree for iModel Viewer (Version 3)
The Model Tree (Tree Widget) in the iModel Viewer is a visual tool that helps you explore, understand, and interact with the structure of your digital twin. It organizes model data into a hierarchical format, making it easy to find, view, and manage elements.
Getting Started
Requirements
Opening the Model Tree
  1. Launch your iModel Viewer.
  2. Locate the Tree Widget panel (usually on the right).
  3. If hidden:
    • Click the Widgets or Tools icon.
Widget example
Understanding the Tree Structure
The tree is organized into:
Each section can be expanded to reveal nested items.
Key Features
Feature
Description
How to Use
Expand/Collapse
View nested elements
Click the arrow (▸) beside a group
Select Elements
Highlights in 3D view
Click on the item
Right-Click Menu
Actions like isolate, hide, zoom
Right-click on an element
Search Bar
Find elements by name or ID
Use the search box at the top
Visibility Toggle
Show/hide elements
Click the eye icon 👁
Common Actions
  1. Zoom to Element
    • Right-click → Zoom to
    • Centers and zooms in on the selected item
  2. Hide Element
    • Right-click → Hide
    • Temporarily removes the item from view
  3. Isolate Element
    • Right-click → Isolate
    • Hides all other elements except the selected one
  4. Reset View
    • Right-click → Reset View
    • Restores visibility to all elements
Viewer Controls Explained
These controls are typically found in the Tree Widget toolbar or context menu. They help you manage what’s visible in the 3D or 2D view.
1.     Show All
2.     Hide All
3.     Invert
4.     Toggle 2D Views
5.     Toggle 3D Views
6.     Enable Instance Focus Mode
Quick Summary of Controls
Control
Purpose
Typical Use
  1. Show All
Restore visibility
After hiding or isolating elements
  1. Hide All
Hide everything
Start fresh or reduce clutter
  1. Invert
Flip visibility
Focus on hidden elements
  1. Toggle 2D Views
Show/hide 2D drawings
Switch between 2D and 3D
  1. Toggle 3D Views
Show/hide 3D models
Focus on 2D or reduce load
  1. Instance Focus Mode
Highlight one element
Inspect or present a single item
Smart Tips
Frequently Asked Questions (FAQs)
Q1: Why is my model empty or missing elements?
A: You may have hidden elements. Right-click in the tree and select Reset View.
Q2: How do I find a specific item quickly?
A: Use the Search Bar at the top of the tree. You can search by name or ID.
Q3: Can I hide multiple elements at once?
A: Yes. Select a category or model group and use the eye icon or right-click → Hide.
Q4: What does “Isolate” do?
A: It hides everything except the selected item, helping you focus on it.
Q5: Can I customize the tree structure?
A: Not directly in the viewer. The structure is defined by Data structure from the source CAD models through the iModel Synchronization process.
Q6: Can I export or save my tree view?
A: Not currently supported.
Important Note: Hierarchy Level Size Limiting
To ensure performance and responsiveness, the Tree Widget limits the number of child nodes that can be loaded at any one level in the hierarchy. By default, this limit is set to 1000 items per level.
What This Means for You:
What You Can Do:
