ICS to PDF Rendition MAS L1 Troubleshooting Guide for Performance Issues with DGN Files Referencin
KB Article:
with DGN Files Referencing DWG in a Hosted Server
Purpose
This guide provides users and support teams with a consolidated reference for identifying, troubleshooting, and optimizing PDF rendition performance issues in ProjectWise, especially when DGN files reference DWG (AutoCAD) files.
Audience and Responsibility
Audience                                   Responsibility
Users
Responsible for preparing files for rendition, applying the check list, optimization practices, and minimizing complexity in referenced drawings before submission.
MaS L1 Support
Responsible for validating user inputs, performing the basic troubleshooting steps and escalating to the Projectwise support for advanced troubleshooting
Projectwise Support
Responsible for advanced troubleshooting, environment-level fixes, orchestration framework configuration, and ICS performance analysis.
What is a Rendition
Rendition is the automated process of generating PDFs from design files (e.g., DWG, DGN) submitted in ProjectWise. This process happens in the background and does not alter your original file.
Problem Summary
Users report long processing times, hanging, or failed renditions when submitting DGN files that reference AutoCAD (DWG) files.
What Happens During Rendition?
  1. A copy of the file and its references is created in a secure working folder.
  2. A PDF is generated from this copy.
  3. The original file remains unchanged.
Pre-Rendition Checklist for Users
Before submitting a drawing for rendition, ensure:
Rendition Optimization Tips for Users
These recommendations help streamline the PDF generation process in ICS, especially when working with complex DGN files referencing DWG files. Applying them reduces system load, avoids timeouts, and improves overall rendition success.
1. Use Saved Views in AutoCAD Before Referencing
2. Apply Clipping Boundaries to DWG References
3. Avoid Referencing Large DWG Layout
4. Turn Off Unused Levels and Layers
5. Minimize Complex Line Styles, Hatches, and Fills
6. Use Level Overrides Sparingly
7. Clean DWG Files Before Referencing
8. Avoid DWG to DGN Conversion Unless Necessary
9. Limit Use of Annotative Scales
10. Reference Only What’s Needed
Common Reasons for Rendition Delays or Failures
  1. External References (XREFs)
Tip: Consider detaching unnecessary references before submitting for rendition.
  1. Annotation Scale
  1. Large File Sizes
Tip: If possible, reduce the file size by cleaning up unused layers, blocks, or references.
  1. Third-Party Tools
Basic Troubleshooting Steps
  1. Gather User Information
  1. Check Orchestration Framework (OF) Service
  1. Check OF Service Memory Usage
Note: High memory usage may indicate the need for purging or a service restart.
  1. Check the Files Size
  1. Stop OF Service (Before Purging Jobs)
  1. Terminate iPlot Processes
  1. Purge Queued Jobs
  1. Clear Temporary Files
  1.  Restart OF Service
  1. Run a Test Rendition
  1. If the problem persists, escalate the case to the ProjectWise Support Team (GTSPWPlotting)
Additional Notes on File Size and Content Complexity
Note: It’s important to understand that the iCS to PDF rendition process does not modify the source drawing. The file is simply copied to the ICS working directory where a PDF is generated in the background. Where no changes are made to the original file.
