Examples - TEMP/W - Overview
This section contains the GeoStudio TEMP/W Examples.
Comparison of Surface Energy Balance versus N-Factor
Convective Surface on Semi Infinite Domain
Effect of Climate on Ground Temperature Response
Effect of Climate on Groundwater Flow in a Hill Slope
Effect of Slope Aspect on Thermal Response
Effect of Snow Depth on Frost Propagation
Effect of Water Flow on Freezing around a Pipe
Freezing Analysis of a Buried Pipeline
Frozen Ground Containment Barrier
Heat Pulse Technique
Line-source heating experiment
Mine Shaft Freezing
Seasonal temperature trends in water capped tailings
TEMP/W Tutorial
Thermosyphon Laboratory Test
Thermosyphons in End View
See also
Examples - SEEP/W - Overview    [Examples]
Examples - AIR/W - Overview    [Examples]
Examples - CTRAN/W - Overview    [Examples]
