Please see our Component Downloads page for instructions on using the examples below and to explore additional component downloads.
This page provides download links for Chart and Template components used to generate lab and other chart-based reports in US configuration packs.
Both the Charts and Template components must be imported for each example.
Please be sure to import the Chart Point Symbols before using these components.
| Item | Chart Component | Template Component(s) | Example |
All |
A single component including all the Charts examples within this table. | A single component including all the Template examples below. | (See below) |
Atterberg Chart |
Atterberg - US | Project Sheet - Atterberg Limits - US GEN | |
Compaction Chart |
Compaction - US | Project Sheet - Compaction Multiple - US GEN | |
Particle Size Distribution (PSD) Chart |
PSD - US | Project Sheet - PSD - US GEN | |
| Project Sheet - PSD Landscape - US GEN | |||
Moisture Content vs. Depth By Location Chart |
Moisture Content vs. Depth By Location - US | Project Sheet - Moisture Content vs. Depth By Location - US GEN | |
SPT N Value vs. Depth By Location Chart |
SPT N Value vs. Depth By Location - US | Project Sheet - SPT N Value vs. Depth By Location - US GEN |
