| Application | GeoStudio |
| Version | Latest version |
| Primary Analysis | SLOPE/W |
| Keywords | GeoStudio, SLOPE/W, Gravity retaining wall, Failure mechanism |
This example demonstrates how to analyze two potential modes of failure for gravity retaining walls using SLOPE/W: deep-seated rotational failure and translation. In most cases, the strength of the wall is very high. It is therefore necessary to filter out any slip surfaces that pass through this material. This is accomplished in SLOPE/W by assigning the wall a special material type called High Strength.
